99 and up came with pi (performace improved) intake manifold, heads, and cams. you can swap these parts over to the 96-98 years and gain about 10-15 more hp because of the raised compression. i have non-pi heads which is why i am sad.
So to make it the engine that is in the 99-04s it woudl cost how much?
weelllll, you could juice your car and make it as fast.
Or you could blow it.
But if you want it the same as the 99+ then youd have to spend like 1500 for a PI swap and then add cams and heads and a tune and thatll prolly be upwards of 2000-2500?
