Recommended Cams?
Old 08-08-2006, 02:16 AM
96GTMustang
96GTMustang's Avatar
Default Recommended Cams?
I just finished my PI head swap on my 96 Mustang GT to the Patriot Performance stage II heads. I was wondering if anyone recommended certain Cams i should use without worrying about upgrading my injectors/ MAF? Right now i am thinking about Comp CAM # 102500 with my 3:55 gears. What do you think? Keep in mind i may be throwing on a blower in another year or so.
96GTMustang is offline
Old 08-10-2006, 09:40 PM
96GTMustang
Default RE: Recommended Cams?
Anyone?? Please..
Old 08-10-2006, 10:03 PM
blstoff
blstoff's Avatar
Comp Cams 262ah cams are popular w/ good idle .
blstoff is offline
Old 08-10-2006, 10:35 PM
04BlueGT
04BlueGT's Avatar
You should be able to run the Comp 270AH also. The range on those is 1800 to 5800. They will have a noticeable idle. You'll need a tune and gears (which you have) to run the 270s.
04BlueGT is offline
Old 08-11-2006, 12:53 AM
96GTMustang
Yeah i think i am gonna go with the 262's. Do you know if the stock cam gears bolt on to the new ones by any chance?
Old 08-11-2006, 01:19 AM
2000 CHP5.1
2000 CHP5.1's Avatar
that depends on whether your factory ones are press-on or bolt-on, if they are bolt-on they will bolt up to your factory ones just fine, if not you will have to buy them.
2000 CHP5.1 is offline
Old 08-11-2006, 01:52 AM
96GTMustang
ok good i have bolt on's so that will save me some $$...W/ these cams will i need to program my car?? If i do, should i do it right after i complete the install??
Old 08-11-2006, 01:59 AM
racer02GTstang
racer02GTstang's Avatar
are romeo engines bolt on or push on? i was told that i dont need new cam gears since i have a romeo in my car? is it true?
racer02GTstang is offline
Old 08-11-2006, 02:14 AM
andy98gt
andy98gt's Avatar
Do not buy cams for a 96-98 GT.... MAKE SURE YOUR BUYING CAMS FOR THE 99-04 GT. They might be differant.
andy98gt is offline
Old 08-11-2006, 02:15 AM
andy98gt
andy98gt's Avatar
Oh yeah and how is your car running???? Pretty fast or what??? You better tune that thing.
andy98gt is offline
Quick Reply: Recommended Cams?
