Where Can I get a H?
I am looking for a H pipe with cats on it and can't find one. Also is a H with cats going to help since the stock H has cats? will there be a difference in sound? If there is no H with cats could I just order a o/r H and then put High flow cats on them? would this mess up the o/r H pipe? Sorry for this post being kind of similar to my other one.
RE: Where Can I get a H?
No cats = louder, less backpressure, more power... you'll also fail emissions testing. You will need MIL eliminators or a hand-held tuner to deal with your rear O2 sensors otherwise you'll end up with a check engine light.
An O/R H (O/R = off road) means that it has no catalytic converters... the other alternative is a catted H.
I'm curious as to where you'd get one for a 99-04 stang also... I don't want to shell out the big bucks for an SLP one, which seems to be the only one I can find.
www.lethalperformance.com this site should have everything you'll need. No, if you buy an O/R H, it just wont be worth putting high flow cats. If you want an H w/ high flow cats...buy one. An H pipe with cats will be more quiet and will be more restrictive, but of course better then stock. Cheap Mid pipes are sold from MAC and BBK. I have an O/R X from BBK arriving tomorrow, hopefully.
ORIGINAL: DROES99STANG
hey 2k1gt do you have the catted H? if so how does it sound?
