need help
Old 08-10-2006, 11:41 PM
Dwabb
Dwabb's Avatar
Default need help
recently my 96 gt has not been acting funny. it doesnt happen all the times i start it but a few. what happens is it will start then in a couple of seconds it dies right away. i dont know what is goin on.
if someone has any idea please let me know.
thanks
Dwabb is offline
Old 08-10-2006, 11:58 PM
46blueStang
46blueStang's Avatar
Default RE: need help
could be somthing to do with the ignition, maybe it cant hold a spark, or its depriving itself of fuel, could be a number of things, if you can give a more accurate detail of whats happening, i could try to point you in the right direction.
if not then first check for spark then check for fuel problems, try getting injector cleaner then work your way back
46blueStang is offline
Old 08-11-2006, 12:15 AM
r0ckster 99GT
r0ckster 99GT's Avatar
My Haynes repair manual says
#1. loose or damaged wire harness conections at distributor, coil or alternator.
#2. Intake manifold vacum leaks. Make sure all mounting bolts/nuts are tight and all vacum hoses connected to the manifold
are attached properly and in good condition.
#3. Insufficient fuel pressure.
#4. Fuel injection or engine control systems malfunction.
you also might want to check and make sure your air filter isn't getting clogged.
Hope this helps??
r0ckster 99GT is offline
Old 08-11-2006, 12:18 AM
crash94
crash94's Avatar
IAC. You need to clean it with some carb cleaner. That would be an easy and inexpensive place to start.
Let me find something...
Here's what I was looking for. Go down through the post and you will find a pic of what you need to clean.
GL
crash94 is offline
Old 08-11-2006, 12:43 AM
crash94
crash94's Avatar
Ok, here's another link that will help step by step and also a pic that will show you where the IAC is on your engine. It's easy, it is bolted to the higest point under your hood. Find the horse.
EDIT: You will need an extension to get to that bottom bolt.
IAC Step by Step
crash94 is offline
Old 08-11-2006, 02:06 AM
Dwabb
Dwabb's Avatar
thanks guys for your help im going to try the carb cleaner then chek the ignition system.
i will let u know how it turns out thanks alot.
Dwabb is offline
