PI head swap questions
I have a 98 gt and i am in the process of doing the PI head swap. I found that the camshaft sprocket bolts from my stock 98 head wont work with the PI heads. The 98 heads use a M12 and the PI head uses a M10. So i went to the hardware store picked up some bolts the correct length and the only washers i could find where from a lawnmower blade. Went to torque them down and snapped one off. So my question is, where can i find the correct bolt and washer to use? Finding a hardened M10 isnt hard its getting a m10 washer. The washer off the 98 head is a m12 so its a little sloppy on the m10 bolt and i didnt want the camshaft to be offbalanced.
RE: PI 4.6 head swap cam bolts
Mine was 2 1/2 weeks. Only reason was that the dipstick broke off and had a hellova time getting it out. Honestly though. If you have 3-4 WHOLE days, you should be fine (depending on your knowledge, and if Nothing goes wrong). I had a lot of waiting for parts here and there.
depends how prepared you are and what u break. This is my second week, only working on it nights, i also installed headers and motor mounts, and broke off a bolt in the camshaft.
for anyone reading this u will also need to put a plug in the back of each head if u buy them new or you will have a big mess. So i got everything together tonight and the car runs pretty rough, do i need to get a tune....diablosport.....?
