Engine problems
Old Aug 15, 2006 | 12:43 AM
97mustanggton18s's Avatar
97mustanggton18s
Default RE: Engine problems
but what about the different factorys...romeo or windsor
Old Aug 15, 2006 | 12:49 AM
droptoppony's Avatar
droptoppony
ORIGINAL: 97mustanggton18s
you just need to use the correct valve covers is all. what pi cams did you use? the ones that came with the heads or a different set?
the windsor heads will bolt to the romeo block with no issues...
Old Aug 15, 2006 | 12:53 AM
97mustanggton18s
I used the cams that came with the head...I dont see how my cam shaft is shorting then eveybody elses...you think he messed up and just doesnt want to take the blame?Ill take some pics tomorrow of the link...it looks like someone tryd to take it apart but never finished.
Old Aug 15, 2006 | 12:55 AM
97mustanggton18s
how much did it cost for you to do your block over...you have forge so i know its going to be a little more...how much should i expect to pay for stock internals...im going to college nect year so im tight in cash
Old Aug 15, 2006 | 01:00 AM
oxfordgt's Avatar
oxfordgt
your block is windsor and so are the 99 heads ford didnt switch to romero till 2002. Correct me if im wrong.
Old Aug 15, 2006 | 01:02 AM
97mustanggton18s
yep...i think so
Old Aug 15, 2006 | 01:03 AM
droptoppony
ORIGINAL: oxfordgt
96-98 is Romeo
99-00 is Windsor (truck engine plant)
01-04 is Romeo again
Old Aug 15, 2006 | 01:06 AM
97mustanggton18s
but 99 heads should work with no problems...like my cguy said that the cam shaft was shorter?correct me if im wrong
Old Aug 15, 2006 | 01:07 AM
droptoppony
my build is pretty expensive since i'm using a Teksid Aluminum block and Forged Cobra crank....now you can use your block and crank to save money. Expect to pay about $1000 for nice forged rods/pistons. I bought mine from www.vtengines.com you will need some machining to your block to clean it up and your rods and pistons will need to be balanced with your stock crank...all this adds a few hundred dollars. Assembly is another few dollars ...lol its not cheap! Where do you live? It helps to have a good modular builder in your area.
Old Aug 15, 2006 | 01:09 AM
droptoppony
the 99 heads do work fine...many many have done that exact swap...i think your man messed up the timing and had ptv plain and simple.
