Weird noise
Old Aug 17, 2006 | 06:29 AM
FRunner's Avatar
FRunner
Default RE: Weird noise
Can't hurt to check that right?
Old Aug 17, 2006 | 06:36 AM
oxfordgt's Avatar
oxfordgt
ORIGINAL: stang23456
No, it's more of a squeaking noise. I dont think its the clutch, I only have 27k on the car
I only have 22K on my 04 and the throwout bearing is chirping.
Old Aug 17, 2006 | 07:40 AM
Stang0005's Avatar
Stang0005
it could be a bad bearing in one of your pulleys. I had a loud squeaking noise and thought it was my alternator at first, but it turned out it was just the bearing on the pulley next to the tensioner. i took it off and had sum1 replace it for like 10 bucks.
Old Aug 17, 2006 | 10:29 AM
RiCe_KiLlEr's Avatar
RiCe_KiLlEr
congratualtions, seems like you have a bad throw out bearing....you are our newest member......seems like everyone has a bad throw out bearing includiing me..
Old Aug 17, 2006 | 12:16 PM
joeybutts's Avatar
joeybutts
can you throw me on the bad t/o bearing list? [:@]
Old Aug 17, 2006 | 01:21 PM
monkeydude3's Avatar
monkeydude3
ORIGINAL: ben790450
OH my car made that exact noise right before the engine blew up and then seized!!!
blew up and then seize?? WTF? lol
It could easily be a belt or pulley, check the simple and easy to replace stuff first. Then again our TOB are known to be pieces of poo
Old Aug 17, 2006 | 01:33 PM
ShadowDrake's Avatar
ShadowDrake
My throwout bearing is noisy... has been since I got my stang with 7500 miles. Enough to hear it over the exhaust at idle from 30-40' away if you know what you're listening for.
Old Aug 17, 2006 | 01:36 PM
monkeydude3
and the dealer wont fix it?
Old Aug 17, 2006 | 01:38 PM
ShadowDrake
ORIGINAL: monkeydude3
Snowball's chance in hell. They don't do -any- work for free. Wouldn't honor TSB's while I was under warranty, and since the throwout bearing is a part that's designed to wear out, they won't touch it. That's the dealerships around here though, I bought my stang in FL from Plantation Ford, they're a helpful bunch and would cover it for me but they're about 1300 miles away at this point [8D]
Edit: I suppose it's all for the better though, I like doing all of my own work on my stang. When my clutch gives out I'll replace the whole deal with nicer stuff. I still need to figure out what Ford does with the steering rack and pinion to correct the clunk/creek noise because I've got that now... and it creeks just barely to the right of center, so whenever I start to make a right turn or switch lanes to the right I get a creek from it [:@]
Edit 2: And a slight tick from the passenger-side head... par for the course with the Romeo block though... Not major and most wouldn't notice it but I hear it when I pull in my garage. Could just be injectors clicking... not an issue to address right now though because my stang hasn't burned a drop of oil this last 5000 miles... Was comforting to see when I changed the oil.
Old Aug 17, 2006 | 01:39 PM
monkeydude3
that sucks dude. Our dealer is usually pretty helpful in situations like that.
