check engine light
Old Aug 16, 2006 | 03:44 PM
rtg20's Avatar
rtg20
Default check engine light
The check engine light has come on in my 96 GT. I took it to the garage, whereupon the light turned itself off! So they couldn't do anything. Now it's back on again, and has been for a few days. The car seems fine to drive, although it vibrates a bit on the freeway and there's a clanging noise coming from the trunk (trunk is empty)...? None of the other warning lights are on.
Any ideas...? Am I damaging my car by driving it in this condition...?
Thanks,
Richard
Old Aug 16, 2006 | 03:45 PM
ben790450's Avatar
ben790450
I ♥ Acer
Default RE: check engine light
check it yourself:
http://mustangworld.com/ourpics/fcar/dtcodes.htm
Old Aug 16, 2006 | 03:48 PM
rtg20's Avatar
rtg20
it says "(99 and 2000 models)" - mine's a 96...?
Old Aug 16, 2006 | 03:49 PM
ben790450's Avatar
ben790450
I ♥ Acer
oh [>:] sorry lol
Old Aug 16, 2006 | 03:50 PM
ben790450's Avatar
ben790450
I ♥ Acer
either way that garage doesnt know what they're doing then! The CEL system stores codes even if the light is off! You can recall previous codes stored in the system.
Old Aug 16, 2006 | 03:59 PM
rtg20's Avatar
rtg20
thanks! How do you recall the code...?
Old Aug 16, 2006 | 04:52 PM
01BlueCobraVert's Avatar
01BlueCobraVert
Go to an Autozone. They do the scans for free. They usually will not do it if the light is off. So explain to them you really need it checked and as long as they are not @$$holes they should check it. They will most likely not be able to tell you what the code means, but they can give you the code and then call ford and ask them what that code means.
Old Aug 16, 2006 | 05:44 PM
d3mon's Avatar
d3mon
o go to o'reillys they give you the scanner and tell you how to use it is not dificult, and then they give you any advise about what to do
djbigskrilla
Sep 20, 2022 01:04 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
