torque mod on diablo tuner????
was lookin around and the torque mod is set to stock, should i change this, also how do you know if your traction control is turned off, i set it to off, but i dunno if its taking, also on wot fuel, being a stock car should i lean the mix out some, i have my shifting firmness set to 200 on wot is that also ok?
anything u guys can suggest to mod this with the tuner would be alot of help
RE: torque mod on diablo tuner????
Torque modulation is what the computer does when you switch gears. It works like granny shifting in a manual. It takes power from the engine so the shift is smoother. Take it off. The "trac off" button in front of the shifter will be lit if the traction control is off. I leaned mine out some but it runs better at the stock A/F settings. Make sure you turn the timing all the way to +10, this is where the power is.
i couldnt find any traction control button, and everytime i switch it to off in the tuner, but it always has the "on" on top which im assuming it isnt turning off, i will take all my torque mod off, my spark is advanced
think its 14 total but the tuner goes to plus 10 i thing if you go under it goes -4.......
ok i keep tryin to turn off traction control i dont think its taking, i have an automatic.. i cant find a buttonand no light comes on, i have a 98gt convert
ORIGINAL: damdanger
ok cool ty anything else i can do to optimize my tune, currntly what i have done is
WOT shift firmness- 200
half throttle shift firmness is 30psi
spark advance +10
torque mod - off
what sensors should i turn off
spark advance +10
torque mod - off
ok i got a new issue, tranny wont shift outta 1st... here is what i did when modding tune, lemme know what i screwed up
took WOT shift firmness from 120 to 200
took the half throttle from 15 psi to 30 ps1
took the torque mod off
help
help
ORIGINAL: damdangerturned the torque mod back on and it shifts gears again, dunno what that was about
