high compression question
Old Aug 21, 2006 | 10:10 PM
torqueaddict's Avatar
torqueaddict
Default high compression question
I am planning on doing the PI swap on my 96. If I have a compression ratio of 10.3 to one on a N/A daily driver, is there any danger to my engine? I will be using 91 octane fuel, as there is not any higher octane fuel around here. So as long as I don't go with forced induction right now and use 91, will I be ok, or are there still any hazards. Thanks a lot for any advice.
Old Aug 21, 2006 | 10:11 PM
2000GT4.6's Avatar
2000GT4.6
Default RE: high compression question
ORIGINAL: torqueaddict
You should be fine, but its all in the tune. If you run a tune with the timing advanced you will need to run 93, but I am sure you can have the tuner set the car up for 91 octane (or the stock tune, which will be fine)
Old Aug 21, 2006 | 10:20 PM
sanitarium16's Avatar
sanitarium16
use premium gas and you will be fine.
Old Aug 21, 2006 | 10:30 PM
torqueaddict
10-4, thanks guys.
bconboy
Sep 21, 2015 12:52 PM
uberstang1
Sep 20, 2015 06:42 PM
04stangman
Sep 17, 2015 01:45 PM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
Sep 8, 2015 11:50 AM
