Full Synthetic Motor Oil
RE: Full Synthetic Motor Oil
the synthetic does indeed cause less wear inside the engine.
The best thing to do is break in the engine with dino oil so it helps develope good wear patterns, and then very early in the engine's life go fully synthetic. Your engine WILL last longer.
I use the semi-synthetic blend. It works well. My car doesn't really eat oil like it used to or anything like that. I will always use the semi-synthetic or full synthetic from now on
ORIGINAL: nanaki
i just pay a local garage to do my oil changes. $29 for a full synthetic change. motorcraft 5w20.
ORIGINAL: Dan04COBRA
Did you fill the oil filter before you screwed it on?
on my GT the filter goes on it's side, so filling it would result in spillage. I don't fill mine, and within a second i have oil pressure
