Oil Changing Questions
RE: Oil Changing Questions
My '03 GT owner's manual says 6 qts, including the filter--and that's what it takes to fill mine. BTW I do fill the filter, sort of--I pour oil into it fairly quickly 'til it's up to the threads and then let it sit while to pan drains, the oil will soak in to the media and you won't spill a drop installing it. The filter is not completely ful of course, however the medai is saturated and that gives the oil flow a leg up when you start the engine.[/align]
ORIGINAL: 2cokeman
how many liters with filter is recommended?
thanks
thanks
