New Stuff
Old Aug 23, 2006 | 11:49 AM
lizzyfan's Avatar
lizzyfan
Underboss
Default RE: New Stuff
It's almost a must with a performance clutch.
Old Aug 23, 2006 | 11:52 AM
Mr_Kebo's Avatar
Mr_Kebo
wow my bad, i misread the install directions. It is under the dash
Old Aug 23, 2006 | 11:56 AM
Mr_Kebo's Avatar
Mr_Kebo
I weighed the flywheel and it weighs 20lbs
Old Aug 23, 2006 | 02:05 PM
Cornbread01's Avatar
Cornbread01
you should get the adjustable cable if you didnt all ready what kind of clutch
Old Aug 23, 2006 | 05:44 PM
Mr_Kebo's Avatar
Mr_Kebo
Spec stage 2
Old Aug 23, 2006 | 06:37 PM
code3GT's Avatar
code3GT
Mustang Nazi
What flywheel is it. GOOD CALL on getting the adjuster with the Spec clutch, especially the Stage 2.
Old Aug 23, 2006 | 06:42 PM
Aixtreme89's Avatar
Aixtreme89
ORIGINAL: Mr_Kebo
Spec stage 2
I got a Spec stage 1 clutch. I wish I went with a stage 2, my clutch is slipping. I needed an adjustable clutch cable also. I would recomend getting that also before you install it so you dont run into any problems. I also have a firewall adjuster and aluminum quadrant. The stock cable attatched but it put way too much pressure on the clutch fork with engaged the pressure plate too much. So beware.
EZFEED
May 5, 2016 08:54 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
humpbackshooter
Sep 24, 2015 10:07 AM
Brett Ludlow
Sep 23, 2015 06:59 AM
