New Stuff
Old Aug 22, 2006 | 08:46 PM
Mr_Kebo's Avatar
Mr_Kebo
Default New Stuff
Well ups came today and brought me some stuff. New clutch,flywheel,quadrant and firewall adjuster.
[IMG]local://upfiles/32229/95CC49FA2E61447D8C26C3B1C31C3702.jpg[/IMG]
[IMG]local://upfiles/32229/34DE41CAB556491985499FA70296A365.jpg[/IMG]
[IMG]local://upfiles/32229/EB3603FCD1444448BD043203EC7AD90B.jpg[/IMG]
[IMG]local://upfiles/32229/817D056B5F854CF19F6C2051FC645E7A.jpg[/IMG]
Old Aug 22, 2006 | 09:00 PM
Rusmisel01GT's Avatar
Rusmisel01GT
Default RE: New Stuff
NICE, too bad i dont know what a quadrant or firewall adjuster are... LOL
Old Aug 22, 2006 | 09:06 PM
Mr_Kebo's Avatar
Mr_Kebo
Steeda Double Hook Quadrant
The factory plastic self-adjusting quadrant is fine for stock clutches, but when you add a heavy duty clutch or some fast power-shifts, it starts to bend. This unwanted flex causes inconsistent clutch engagement and missed shifts at best, plus worn synchronizers and a broken quadrant at worst. Replace that weak plastic clutch quadrant with Steeda's super strong billet aluminum "Double Hook" quadrant. The strong flex free billet quadrant design stands up to the hardest shifts.
Steeda's exclusive Double Hook design lets you use your choice of an adjustable clutch cable or firewall mounted cable adjuster. Or use both together for the ultimate adjustment versatility. With other quadrants you are locked into one type of adjustment mechanism. With Steeda's Double Hook Quadrant, the choice is yours!
Steeda Firewall Cable Adjuster
New Set-screw keeps cable in place with no need for re-adjustment. Set it once and forget it.
Looking for an easy way to adjust your clutch? Steeda's firewall mounted clutch adjuster lets you adjust clutch engagement without having to crawl under the car. Just turn the adjuster **** on the firewall and you're done! Of course you expect the best from Steeda, so we went the extra mile and designed this part with a bigger adjustment range than the other guy's, plus a handy locking tab so you can adjust it with one hand! Must be used with Steeda's Double Hook Quadrant.
Old Aug 22, 2006 | 09:40 PM
Brute03's Avatar
Brute03
so where exactly does the quadrant go? i don't know much about it either
Old Aug 22, 2006 | 09:44 PM
Mr_Kebo's Avatar
Mr_Kebo
It actually bolts at the bellhousing under the dust cover.
Old Aug 22, 2006 | 10:04 PM
99gtstang's Avatar
99gtstang
what size flywheel????
i almost bought a lighter one they was told puts a strain on tranny, RPMS rev up to fast... and the minute you let of the gas car will slow down dramatically
99gtstang's Avatar
99gtstang
nice items though......
firewall adjuster always nice, verses going under car and messing with the dust cover
Old Aug 23, 2006 | 11:32 AM
Mr_Kebo's Avatar
Mr_Kebo
Ive never heard that.. is there any truth to that guys
Old Aug 23, 2006 | 11:34 AM
4.698GT's Avatar
4.698GT
It should take some strain off the drivetrain because it is lighter then the stock. It will rev up and down faster though.
Old Aug 23, 2006 | 11:47 AM
S281SC's Avatar
S281SC
ORIGINAL: Mr_Kebo
Uh no, you'll find the quadrant under the dash - connects the cable to the clutch pedal.
