Fuel Injectors
Old 08-23-2006, 10:18 PM
clix813
clix813's Avatar
Default Fuel Injectors
Well I figured that I will buy some new fuel injectors but im not sure what size to get. If you look at my sig for what I have.
clix813 is offline
Old 08-23-2006, 10:21 PM
code3GT
Mustang Nazi
code3GT's Avatar
Default RE: Fuel Injectors
Unless yours aren't working, you don't need new ones. You will get ZERO performance gains out of bigger injectors with your mods. Just my .02
code3GT is offline
code3GT
Mustang Nazi
code3GT's Avatar
deleted, double post.oooops
code3GT is offline
Old 08-23-2006, 10:27 PM
lizzyfan
Underboss
lizzyfan's Avatar
ORIGINAL: code3GT
+1!!!!!
lizzyfan is offline
Old 08-23-2006, 10:45 PM
01BlueCobraVert
01BlueCobraVert's Avatar
What made you want new injectors? I am putting on every bolt-on, cams, alum. driveshaft , you name I will have it. I got 24lbs injectors for my car and was told I probably could have just used my stock 19lbs.
01BlueCobraVert is offline
Old 08-23-2006, 11:26 PM
clix813
clix813's Avatar
well my car is at 968000 and figured that it could use some new ones.
clix813 is offline
Old 08-23-2006, 11:29 PM
01BlueCobraVert
I just hit 100000 and mine still work fine. If you are that worried pay 10-15 bucks and run some fuel injector cleaner through your gas. I would change the fuel filter before injectors.
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: Fuel Injectors
