this is my first 4.6
hi,i just purchased a 97 cobra 4.6.until this i have been a devoted 302,351 fan. car is mostly stock,with cats removed,and some type of chip.i was told it had bigger injectors,but they are F55E-A2E,which i believe are stock.he also said he thought it has a high volume fuel pump.it runs great,but smells like gas a lot.is it because the cats are gone,the chip,fuel pump,bad regulator?i could use some help in figuring this thing out.thanks.
RE: this is my first 4.6
ORIGINAL: jdaniel
well its all because you dont have cats. The smell will go away as soon as you get used to it!
well the reason I say its the cats is beacuse I had my offroad X out on and that was the first thing I noticed was the gas smell so I turned around and had him check the A/F and all was fine. Just not burning the extra fumes that you normally wouldnt smell with cats.
[sm=smiley36.gif][sm=smiley36.gif][sm=smiley36.gif] Well I dont know where else it wwould be going if my car has the right A/F ratio going where else would the smell be coming from? I believe its the cats.
ORIGINAL: jdaniel
I have the same thing goin on with my car and i know it's from taking off the cats, cuz right after i got the o/r x on i started it and it smelt like raw exaust. It will most likely smoke a little to when taking off but i think that is normal when taking off the cats (at least mine does anyways).
