need some advice
ORIGINAL: ben790450
Yeah full bolt ons. Heads. Cams. P-51 manifold. 75 mm setup. 85 mm maf. 24# injectors. Get a tuner and have them tune it at a shop.
The MAF is not becuase of the sensor its becuase of the inner diameter. A stock MAF can read anything us 2v n/a guys could ever do (given you have stock injectors) but its the inner diameter. You only flow as much air as your smallest opening. If you have a 75 mm CAI and 75 mm TB and a 75 mm UI what good is it when you have a 65 mm MAF? Your never moving more than can fit through a 65 mm space.
ORIGINAL: ben790450
You don't need stock injectors to keep the stock MAF.
But then you have to have it tuned. The stock MAF only knows the stock injectors. It wont "automatically" know what injectors you put it. It has to know what size injectors you put in to correctly determine the fuel pusle width
ORIGINAL: ben790450
Omgitsa88Stang
Oct 5, 2015 07:33 AM
