Code 5284??help??
http://mustangworld.com/ourpics/fcar/dtcodes.htm
i just cheked the codes on my 00gt and this code pops up i know what it means ( 5284 Oil Pressure Switch Failure ) but my car says it has good oil pressure on the gage, but i tryed to put it on the digital gage and it says while the car is running 000 ?? whats that about ?? what do i do about the code is there a issue with my car ??
ORIGINAL: mattmoto441
Isn't that one of the normal codes? While it's running, 000 means that you have more than 9 psi of oil pressure... 255 means you have less than 9 psi of oil pressure. That code will come up because when you go to start your car, you turn the key into the on position before the engine is running and pumping oil, don't you? The code stays till the car is turned off.
ORIGINAL: ShadowDrake
ohh so the code will shut off when the car is running??
lincolnshibuya
Dec 8, 2015 04:37 PM
