car starting problem
Old Aug 29, 2006 | 10:10 PM
Smooth_J's Avatar
Smooth_J
Default car starting problem
We been having a wet week/weekend over in NJ and finally the rain let up and I tried to start my car. It will crank and crank, but it wouldnt go over. Then finally it went over and then it stalled. I tried it again, and the same thing happened. I tried it one more time with some gas (for about 5 secs) and it kept the RPM up and I could ride it. I tried it again today, same issue.
I assumed it was a battery problem so I checked the leads and everything was good.
Spark plugs have been changed around 40k or so ago
Gas filter around 15k
Battery, no idea
Oil is around 2k
Anyone have any ideas?
Old Aug 29, 2006 | 10:13 PM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: car starting problem
Sounds like the fuel pump or fuel pressure regulator is bad.
Old Aug 29, 2006 | 11:00 PM
Smooth_J's Avatar
Smooth_J
ORIGINAL: sprostang
I hope not.... two things that will cost a pretty penny
What PSI should my fuel be when my cars off?
Old Aug 29, 2006 | 11:14 PM
stang2000's Avatar
stang2000
Again sounds like a fuel related issue. Fuel Filter is like $10.00 and a new pump somewhere about $150.00 not that expensive really. I just bought an SVT Focus pump for $104.00. Also possibly check your MAF to make sure it's clean and tight on the hoses. but more like thanelu it's a fuel issue.
Old Aug 29, 2006 | 11:22 PM
sprostang's Avatar
sprostang
I ♥ Acer
ORIGINAL: Smooth_J
ORIGINAL: sprostang
After car has been off, the fuel pressure should be between 30 to 40 psi.
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
ShaneB26154
35
Mar 4, 2021 04:05 AM
Soldier GT
12
Aug 20, 2015 09:42 AM
Milan Dragway
Aug 12, 2015 03:43 PM
J.casone400
Aug 7, 2015 08:40 PM
