mustang lagging on hard acceleration
here's the thing car runs great,perfect idle,only when i get on the gas/wide open throttle,it seems to lag.I'll punch it and it'll climb great then about 3800 rpm's its sluggish.This just started to happen a while back ago,i changed the fuel filter,changed the oil and filter,im running out of options,can anyone help with this?
RE: mustang lagging on hard acceleration
I just had the same thing happen to my car last weekend. I changed the fuel filter, cleaned the air filter, cleaned the throttle plate.-I tw as still doin it though. I started to check my plugs and when I got to the secod plug, I realized a vacuum line from the intake pipe to the plenum was disconnected. It took me 6 days to figure it out. So you may want to double check all your hoses. Amazing how one hoe will cause that much of a nuisance
ORIGINAL: SNORX302
ORIGINAL: 98HossGT
man don't you know pimpin aint easy
ORIGINAL: SNORX302
could this problem be because of the intake a while back ago the intake stripped out where the spark plug screwes into it,supposidly they fixed it,im thinking about just changing the intake,but i want to go with a s/c later on,any advice and could this be a reason?
