Supercharger question
RE: Supercharger question
I'd keep the boost at 6psi or lower without the IC.
The more you compress the air the hotter it will get. Without an IC, you eventually will not be able to control detonation due to the high incoming air temp. The IC helps cool the air back down after it has been compressed and before it enters the intake.
ORIGINAL: ShadowDrake
~340 RWHP... but non-intercooled is playing with fire. Sooner or later the engine will go pop.
ORIGINAL: LvGordo
ugh. there are alot of people running 8#s and more for a long time non-i/c and they are just fine. It is all in the tuna.
ORIGINAL: LvGordo
ORIGINAL: JJ03MustangGT
if i were u go with the i/c charger. in the long run its worth it.
treesloth
09-28-2015 07:03 AM
