P.I. Conversion
i ask this because i posted earlier asking how much power id get out of a stock 98gt w/ aftermarket headers, exhaust, intake, pulleys. someone posted id be better of doing the P.I. conversion
getting stock heads 99-04 heads is kind of stupid though, yeah you're making power but you should just go all the way and get high perf. heads because ppl w/ 99-04 heads will just get them n still be faster anyway.
Get some 99-04 heads... have them ported & polished while they're out... if you can hold out, put as much money into them as possible (within reason of course) before you put them on... so hopefully you'll never have to take them off to have work done on them.
What I think most people don't realize is there aren't any good 2v aftermarket heads. The ones that are around are just stock heads that have been reworked.
P&P is taking the head and porting out the air passageways (making them larger). Obviously, larger passageways = more air flow = more power. Polishing has the same effect, smoothing out the walls of the passages helps air flow unrestricted, again giving you more air flow through the head, and coming out to more power. The weak link of the GT's are the heads!
ORIGINAL: silverstang1996
ORIGINAL: ShadowDrake
ORIGINAL: chilledfresh
And for a stock GT, what kind of hp improvement will a P&P result in? Or does it just free up the airflow for other mods?
