help!!!!!
Old Sep 2, 2006 | 09:14 PM
memphissfinest's Avatar
memphissfinest
Default help!!!!!
im still at work right now because i cant figure out how to get my car to stay on. It will start just fine and i can put gas to it but when i take my foot off the gas it dies and shuts off. I was thinking something with the fuel line? maybe i need to reset it?
Old Sep 2, 2006 | 09:21 PM
Cornbread01's Avatar
Cornbread01
Default RE: help!!!!!
you can try that disconnect the battery for five mins see if that works hopefully nothing major did it act weird b4 work at all
Old Sep 2, 2006 | 09:22 PM
stang2000's Avatar
stang2000
It may sound stupid, but make sure you have gas.
Old Sep 2, 2006 | 09:30 PM
memphissfinest
well it did the same this morning but it eventually started up. my fuel gauge is showing i have a quarter of a tank. dont know what is going on. [:@]
Old Sep 2, 2006 | 09:42 PM
Cornbread01
when you get it started and have your foot on the gas does it sound normall????
Old Sep 2, 2006 | 10:09 PM
memphissfinest
yea it sounds normal. but i finally got it to start. i just kept switching from off to on a couple times to pump fuel to the engine then it started. then i drove to the gas station and filled all the way up. its driving and starting fine now. i guess my fuel gauge is off? it said i had a quarter tank left but i guess i was running empty.
Old Sep 2, 2006 | 11:04 PM
Cornbread01
have you changed your gauges to white face gauges and how many gallons did you fill up today a empty tank will take about 15.8 gallons
Old Sep 2, 2006 | 11:43 PM
korn253's Avatar
korn253
it is possible to shut off ur fuel pump, the manual says something about if it doesnt start make sure ur fuel pump is on
Old Sep 2, 2006 | 11:58 PM
crash94's Avatar
crash94
IAC been cleaned lately? If not, get some carb cleaner and clean it out.
Old Sep 3, 2006 | 12:06 AM
droptoppony's Avatar
droptoppony
ORIGINAL: crash94
Thats what it sounds like to me...exact same symptoms as when mine went bad....very easy to check and replace.
