All of a sudden my right window wont roll down. You would think this wouldnt be an issue on an 03 but i reset the computer and tried some other miscellaneous things. What yall think ? I dont think its the window motor either
for some reason i hear of this a lot in mustangs, and it usually is the right window. Try taking off the door panel and seeing if the window somehow got off track.
I was actually thinking it got off track too. Cause when i rolled it up the past couple of days i would notice that it was going a lot higher up than it usually would...i dunno sheesh
try putting it up and listen to hear if you can hear the window motor groan or the window creak... if it tries to go up, it may just be the switch is bad
ooh I wanted to ask, have you tried doing the window with both switches? Driver control and the pass. control? If they both don't do it, it could be the motor [&:]
Ya both switches wont work..I wouldnt think it would be the motor usually they dont just all of a sudden go out do they ? Usually you can slowly hear them start to wear out
