Where do jack stands go...
in the rear end? I am going to be installing a bassani SS cat-back (read WOOHOO) and am not sure where they go in the rear. Thanks! (oh, and any tips on how to post clips when i get it on would be appreciated!)
RE: Where do jack stands go...
Just jack your car up by positioning a floorjack on the differential then place your jackstands on the axle between the wheel and the shock mount/bracket. Thats what I have always done when working outback on any of my cars.
i don't have s/f connectors, that will prob be coming next.... is it ok to jack up under the diff? and put on the axle? I thought i read somewhere that it wasn't good for the drivetrain... just askin...
oh, and my jack is too tall to really get under the car unless i drive up on some wood or something...and ramps don't work either!, at least not the ones i have....
http://mysite.verizon.net/txsnakecharmer/jacking.htm ~ I have heard that the reason why you shouldnt jack you mustang up using the pumpkin/diffrential is because the back axle has a slight angle to it, and doing so puts alot of stress on the axle. This should help and i think it should be a sticky i have told many people about it
Take a look at the pumpkin. You'll see why they say not to use it as a jack point. I still use it, just be careful where you place the jack.
For working on the exhaust, you'll want to place the stands under the subframe in front of the axle to allow the axle to drop. That will give you a little more room to work.
ORIGINAL: joeybutts
ok... so i can jack it up by the axle, but not the diff...ok...thanks so much everyone...and i can't wait for my exhaust!!!
How about the front of the car? Where do the stands need to be positioned for the front of the car? I drove my car on ramps, but I am not able to get all the way underneath it. I am changing out my stock H-pipe to an O/R one.
Sorry, I didnt mention I have a '08 and I know this thread is not for the S197s.
