Should I ? PI conversion
Old 09-07-2006, 10:35 AM
candeman
candeman's Avatar
Default Should I ? PI conversion
Recently purchased '98 GT with 90k miles. Have considered converting to PI system. Is the cost and work involved worth it or should I just upgrade to a '98 cobra or newer model Stang?
candeman is offline
Old 09-07-2006, 10:39 AM
so1o2k3
so1o2k3's Avatar
Default RE: Should I ? PI conversion
Personally, I would just look for a Cobra.
so1o2k3 is offline
Old 09-07-2006, 11:12 AM
hotrod7687
hotrod7687's Avatar
If you can find one for a good price, then I would look into getting a cobra. The PI swap will be a lot cheaper than buying a new car, but if you're looking for performance to match a cobra, the PI swap wont get you there.
Before you go out and buy another car, look into swapping a cobra motor into your car. There are a lot of posts about swapping a 4 valve motor in place of your 2 valve here, look back at some of the older threads and you'll find lots of info on it.
hotrod7687 is offline
Old 09-07-2006, 11:27 AM
monkeydude3
monkeydude3's Avatar
there are several kits for around $1300-1400 that include EVERYTHING to do a pi swap... heads, valve covers, intake manifold, and ALL the mounting hardware. They even come with spark plugs. The kit I plan to buy is from "Steen Racing."
Just run a compression test on your engine and see if it's good, if it's good your bottom end is fine. I did a compression test on mine and it came up 145-150 psi all around. That's right at specification. I blow smoke like no other when at operating temp and during and after idling. Valve guide seals... so the heads are being replaced.
Best of luck
monkeydude3 is offline
Old 09-07-2006, 12:46 PM
droptoppony
droptoppony's Avatar
The PI swap for @ 1300 dollars will make your car as fast as 99-04 GT's and put you almost equal to 96-98 Cobra's...add some cams and you will take NA Cobras easily.
droptoppony is offline
Old 09-07-2006, 12:48 PM
2000GT4.6
2000GT4.6's Avatar
ORIGINAL: droptoppony
+1.
Unless you definatly plan on FI down the road, the PI swap should be every 96-98 owners first mod (after gears)/.
2000GT4.6 is offline
Old 09-07-2006, 03:40 PM
SSFenris
SSFenris's Avatar
hey, I'm about to have a set of PI stuff (heads, cam, intake) up for sale. These are take-off parts with under 19k on them... I'd be willing to let it go for about a grand. PM me if you'd be interested.
SSFenris is offline
Old 09-07-2006, 07:40 PM
droptoppony
thats not cheap at all! I paid $350 shipped for PI heads/cams and $125 shipped for the intake and those are avg prices...
Old 09-07-2006, 09:20 PM
aMerICAn_mUsCLe79
aMerICAn_mUsCLe79's Avatar
u deff need to. I know i talked about it a few months ago...and i still am doin it just havnt started yet. Im goin to school in Oct for automotive and i talked to the teacher and when we do the cam intake and head part we can use my car to learn, so to save some money ill do that, but am deff doin it. u want some respect with a non pi and some power to fool ppl deff should do it
aMerICAn_mUsCLe79 is offline
HRnB
GT350 S550 Tech
12-18-2015 09:35 AM
11-10-2015 11:39 AM
DCole24
09-11-2015 10:50 AM
YoungStangsMan
09-05-2015 07:01 PM
Quick Reply: Should I ? PI conversion
