Please HELP!!!! tranny trouble!!!!!!!!!!!!
I just lost 3rd & 4th in my tranny.
Dose anybody know what needs to be modified to put in a t-56 if so any idears on caust for additional parts (not including tranny)???
is it worth the money and hassel or am i better off rebuilding my t 45???
if there are any other options for trannys please let me know i need help ASAP!!!!!
my car is a 99 gt curently w/ a t 45.
Thanks guys!!!!!!
Thanks guys!!!!!!
RE: Please HELP!!!! tranny trouble!!!!!!!!!!!!
I'm sorry i'm just stressed out.
is it worth moddifing the car for a t-56 i.e what parts are needed or should i just get the tranny rebuildt or r there any other options i should be looking into i.e. any other tranies like the better one out of the 2001+ mustangs(i forget the modle but i know the sincro gears r better
whats hard is a conversion from an auto to a stick, manual to manual shouldent be too bad you can buy a t45-t56 complete kit with everything you need to get what you want done as for your tranny problem not enough details of the problem
the tranny nolonger shifts into 3rd or 4th my mechanic told me it needs a rebuild.
every sight that has a t56 says to install on a 99+ gt you may need to modify your chassie.
i was wondering WHAT needed to be modifyed and What additional parts would be nessary to complet the swap???
they sale the modification with the kit, and yeah sounds like your valve body if you want a cheaper way to fix it and add performance get a performance valve body will give you firmer stronger shifts and fix your tranny problem.
