Racing with Nitrous
Old Sep 9, 2006 | 03:36 PM
Quicktime_GT's Avatar
Quicktime_GT
Default RE: Racing with Nitrous
ORIGINAL: ben790450
RUn the highest octaine you can. Your car has an octaine sensor and will adjust accordingly if it needs to if its drastically too rich. [sm=nxsmile.gif]
Are you sure? I don't believe there is such thing as an octane sensor. There is o2 sensors, which measere fuel air ratio, and there is a knock sensor, which would pick up on detonation that would occur if you was running to low of octane.
I may be wrong, but if there is an octane sensor where is it at?
Old Sep 9, 2006 | 04:16 PM
2000GT4.6's Avatar
2000GT4.6
ORIGINAL: ben790450
No car is equipped with a octane sensor. There is no such thing as an octane sensor in fact.
There are "knock" sensors" on certian cars that can pull timing if need be, but i do not believe that our car has them either.
Also, octane has nothing to do with the car running rich or lean.
Old Sep 9, 2006 | 04:50 PM
Quicktime_GT
exactly...simply put: octane is a rating of how much compression and heat the fuel can take before it self ignites> or detonates.
Also willis98cobra- if you are going to run this much nitrous you might want to back off the timing a little, this will also decrease the chance of self detonation
Florida Regional Chapter
Sep 30, 2015 08:04 PM
guitarman376
Sep 30, 2015 05:54 PM
Sep 29, 2015 03:23 PM
mungodrums
Sep 28, 2015 10:54 PM
