Are you getting gears installed and some good info
RE: Are you getting gears installed and some good info
Good article. All I have ever heard is only go with FRPP gears. 700 dollars for gears install is outrageous (sp). It is a pain but not big of a pain, I think i paid 50 bucks in pizza and beer for the guys helping me.
ORIGINAL: Fryguy22
eric do you have specific links to those tools. I plan on helping a bud install is and thought it would be great to have them.
Dial caliper
Inch/pound torque wrench
Foot/pound torque wrench
1†dial indicator with magnetic base
Female Torx E-8 socket
Impact Wrench (optional)
½†breaker bar
12mm 12 point socket/combination wrench
this is the list from the article, BUT you dont need a press, kragen will rent the bearing puller (get both sizes large and small), you will need this to take the flange off and the bearing from the pinion, i used heat from a torch to "bang the old pinion out" and brought just two new pinion bearing from ford and reused the old resses, I did not want to worry about not pressing the resses to the right spot plus the old bearing a resses looked perfect. you heat the new bearing on a skillet and they will slide on, ebay will have the all the other "tools" you really need the e-8 female torx for the abs that i found at NAPA auto parts, and make sure you have a 12 12point socket very important for driveshaft removal, i did not have i inch pound wrench as i have worked on alot of bearings with boats, trailers and cars, and just tightened it till i felt very little drag, i have a foot pound wrench but locktite and some muscle and u can skip that tool also, the dail indicator with base and dial caliper are the most important and make the install fun you have to have a basic install kit with shims(ebay $60) or you will not get this right it comes with extra nuts and bolts, just do what i did and measure the run out and back lash of the stock gears so u have a referance of whats good and youll feel like you did a better job....
ORIGINAL: ericdiver
well like i said in my other post, its not hard to install them, i did it in about 6-7 hours 2 weeks later and 300 miles not a peep from them all you need it $75 dollars in special tools, time, garage, and 1/2 a brain
ORIGINAL: SINISTER
That's not too bad. Did you have a lift or did you get under the car, or what? Also, how mechanically inclined are you? Between my friend and I, I'm sure we could handle it, just want to get an idea of what I'd be in for. Thanks bud.
ORIGINAL: ericdiver
Thanks man, appreciat it. I may PM you in the future for some pointers when that time comes. I've done springs, my intake manifold, shifter, CAI, and a few other things on my car, so if you say it isn't that bad I feel that between my friend and I we will have no problem doing the intsall. Thanks again bud.
ORIGINAL: SINISTER
I'm between 4.10s and 4.30s, but leaning towards the 4.30s. I don't do a whole lot of highway driving very often and the RPM difference on the Gear Calculator is very minimal. Also, I'm going to stay N/A and I would like to be a little different, and I think it would be a blast to drive either way. Thanks again for the advice and the link, it makes it seem do-able. I'll probably attempt this in a few months, and you may get a PM from me then for some advice. Thanks in advance.
good luck y email is ericdiver1@yahoo.com sometimes i dont go on these board for months because its the same questions over and over....
