4.10s and DR's= slower time??!?
2010 Blue Ball Award Recipient
RE: Drag radial psi>??
1) you arent getting traction cuz of them which i think that is your problem
it went from a 2.166 yo a respectable 2.054
my only other suggestion, though you kind of already tossed it aside with one of your comments earlier, is that youre shifting was HORRIBLE that run...but if you said everything felt normal, and youre shifting was just like usual, then im not sure what would have caused it
ORIGINAL: 72MachOne99GT
that would make sense, however his 60' DID improve...
i have those nitto 555rs but in a 285 on an 18x9. its a sick tire.. wear them in for like a week.. they should hook really always..
maybe its the 410s.. they need a bigger.. tire? like over 315? mm on a 18x10 or so. APC do you suggest going with 373s over 410s if i were to s/c soon.
well he prolly eased it off the line without spinning to get that 60 then after first gear he then powershifted into 2nd and spun and maybe spun when he powershifted into 3rd.
so you guys think maybe the spinning took place after the launch.. thats possible, though not nearly as commong as spinnign at the line..hmm, i guess maybe tath could explain the higher trap speed too....
yea, look at his 60 footers.
This isn't the first time I've heard of this either, and I had asked some friends on another forum about this...
For some reason, jumping to that short of a gear seems to drop Trap speed and even w/ speed shifting, you're still not spending as much time in a given gear, meaning more shifts...
Whether that's the absolute case, I don't know, but I have a hard time believing that your tires were the culprit, especially if your 60ft dropped...
What was the temperature at the track?? Did you hit the water box??
JT
JT
RE: 4.10s and DR's= slower time??!?
ORIGINAL: apc fo life
Hey... just took my car to the track last night for the first time after I put in the 4.10s. Before with 3.27's and 285 mastercrafts it ran a 13.7. Now with 4.10s and 275 Nitto Drag radials, the best I could get it to run was a 13.8... This was also with slow 2.054 60'
How much air should I run in the DR's they actually seemed to spin pretty bad, even after heating them up quite a bit.
Is it the tires or have 4.10s slowed my car down, this was at the same track with similar weather conditions, leaving the line @ about 3200. Even when the tires hooked I couldnt cut a good time... []My car is so unconsistant
if anything, it should help trap speed,,,he's still in each gear the correct amount of time.. if anything, he'll pulling through them harder and thus achieving the gears max power at a quicker time, then, when he shifts to the next gear, he is already closer to the best point than he would be if he were still on a stock gear
im not saying that the idea im trying to say is wrong is your own independent idea, but based on that simple reasoning, nobody would benefit from a gear swap...
ORIGINAL: mattmoto441
did you have the rims on you car in the sig on when you ran the first time?? or did you have stock rims
however... yes I did actually spin through 2nd somewhat... then bark thrid... and chrip 4th.... I would leave the 1/4 in 4th coming on the red hard...
who knows... its nothing to stress out over guys.. I know 4.10s and DR's dont make a car slower, its probably got more to do with me learning how to make use of the new set up My car is also unpredictable.. I have been to the track 4 times in this car.. the first time I came back with a 14.1.. the second time a 14.4 the third time a 13.7 and now a 13.8.
