Misfire on cylinder 3!!!
Pulled the codes on my flashing CEL yesterday and it also said "bank 2 lean". I'm gonna change the plugs and see if that fixes the misfire. I'm thinking I've got a bad O2 sensor and that's what's causing the car to run lean... Could that be the problem or am I looking at something else??? Any suggestions for stock replacement plugs?
Thanks in advance guys!
RE: Misfire on cylinder 3!!!
ORIGINAL: 99roushgt
its an o2 sensor more than likely or it could be a vaccuum leak either one had the same problem and was the 02 it will even idle ruff sometimes
thats funny, bank two is the driver side but cyl. 3 is on the pas. side. maybe you should reset the pcm then check the codes when the light comes back on and see if you still have the lean code
ORIGINAL: Brute03
ORIGINAL: Emann0007
I was just thinking that. Looked at cyl 3 and realized the TB and plenum are gonna have to come off to change the plug. Bank 2 is prolly just cause of the O2 sensor (I hope). I didn't figure the problems were related in any way. I reset the computer and the CEL came back on on the 3rd start. It's no longer flashing (I hear flashing indicates a msifire). I'll swap the plugs and get new wires and then have the codes pulled again. I hate this. I don't have time for this ****.
