Can't get into Reverse!!!
Old Sep 19, 2006 | 02:22 AM
CobraStangGT16's Avatar
CobraStangGT16
Default RE: Can't get into Reverse!!!
ORIGINAL: korn253
if u read the manual it says ur supposed to go 3rd 4th reverse, ive found that sometimes i have to let off the clutch after i start it and then press it again, idk y, fords gay
WTF? The last owner lost the manual so I havn't read it yet. But that is weird. Might as well try it though, if thats what it says.
Old Sep 19, 2006 | 02:26 AM
M1ke's Avatar
M1ke
putting it into 1st first helps a lot for me
Old Sep 19, 2006 | 02:29 AM
Fryguy22's Avatar
Fryguy22
i always do 5th then reverse. Or just let off the pedal and try again. Always works after a while.
Old Sep 19, 2006 | 03:14 AM
Rusmisel01GT's Avatar
Rusmisel01GT
You have a short shifter?
Old Sep 19, 2006 | 03:54 AM
yetihairball's Avatar
yetihairball
Yeah, mine goes into reverse if I just let it roll a little bit...I'm talking like maybe an inch back or forth and reverse goes right in.
Old Sep 19, 2006 | 04:13 AM
uofipilot's Avatar
uofipilot
Sometimes I have to put it in first, and move an inch or two. Then it will slide right into R. T45 = Gay.
Matt
Old Sep 19, 2006 | 09:49 AM
mylongvictor's Avatar
mylongvictor
everyone has there own special way of getting it into 5th gear on the 02-04 5sp Mustang trannys. Kinda different from every car. I find that if I yell at my car in a loud angry voice and threaten to trade her in for a 05+ Mustang or a 03/04 Cobra, she listens. Weird huh?
Old Sep 19, 2006 | 09:58 AM
mustangGTdude1031's Avatar
mustangGTdude1031
mmmmmmm, the wonderful world of autos........ meh, who am i kiddin?[>:]
Old Sep 19, 2006 | 11:13 AM
jlong00's Avatar
jlong00
Justa an FYI -- the reverse gear doesn't have synchro -- it's just straight cut gears engaging. The input/output shafts must be spinning at same RPM for gears to mesh easily, otherwise they grind or don't engage at all.
Old Sep 19, 2006 | 02:02 PM
Chris080486's Avatar
Chris080486
I had this problem too in the past. I found that parking it in 1st instead of neutral for me helped alot, but the problem still persists every once in awhile. I am just glad to know I am not the only one with this problem.
