Gas shutoff switch
Old Sep 22, 2006 | 02:15 PM
DaOutLawEdgeJames's Avatar
DaOutLawEdgeJames
Default Gas shutoff switch
Does the 2000 ford mustang gt have a gas shutoff switch? If so would it be in the trunk?
Old Sep 22, 2006 | 02:18 PM
Colt3888's Avatar
Colt3888
Default RE: Gas shutoff switch
the inertia switch(fuel cut off) is on the driver side underneath the lining on the back side of the trunk
96GT226410's Avatar
96GT226410
CSMG Moderator
It's a fuel pump cut off switch. It's in the trunk behind the carpet panel on the left (driver's) side.
Old Sep 22, 2006 | 02:23 PM
pallidamors's Avatar
pallidamors
Banned
Yea its in the trunk. Its a cable attached to a handle that you pull up.
Old Sep 22, 2006 | 02:24 PM
DaOutLawEdgeJames
Thanks, I'll check it out! Im trying to find out why my car runs great then stalls every once in awhile. it's driving me nuts!
Old Sep 22, 2006 | 02:40 PM
DaOutLawEdgeJames
Well I found a red button on the drivers side trunk but no cable. can you only reset it when it shuts off?
Old Sep 22, 2006 | 02:47 PM
Dan04COBRA's Avatar
Dan04COBRA
If your car runs great and occasionally stalls out, it's absolutely not your shutoff switch, without a doubt.
It's more likely to be your IAC.
Old Sep 22, 2006 | 03:09 PM
snowborderz's Avatar
snowborderz
at the bottom of the red button, right below the case, there will be some wires running into the bottom, with a clip holding the two together, unhook the clip, pull the wires away from the casing, and let the car run til it dies
Old Sep 22, 2006 | 04:00 PM
DaOutLawEdgeJames
You're probably right but I wanted to check everything, I thought maybe the wires were bad or some kind of short. I posted last week but no one seemed to know exactly whats wrong with it (it could be anything I know).
Whats an IAC, I havent worked on a car since 2000.
Heres a link
https://mustangforums.com/m_1969951/...tm.htm#1969951
Old Sep 22, 2006 | 04:29 PM
Dan04COBRA's Avatar
Dan04COBRA
Most likely an IAC issue compounded with a faulty TPS maybe.
If the car cranks and you smell gas, it's most likely not a fuel pump issue.
