which car
#21
RE: which car
why does the copression ratio blow on it its like a brand new motor i dont know a crap load of info on mustangs but im on my way to and why wouldnt i be able to s/c in the future????? just wondering not trying to be a d!@K
ORIGINAL: hdawg06
Personally I think the gas crisis is over-exaggerated. It is $1.96 here, and has gone down almost $.35 in a month. I see it going down for a bit more. I wouldn't worry about it. The turbo integra sounds nice, but do you want FWD again? I know I hated FWD, and will never go back to it. If this is just a car to get back and forth to work, don't get either, but if power is something you want, then the mustang may be better in the long run, but 2vs do suck ***. Especially the non-PI engines. I know yours has the PI swap, but the compression ratio on it blows, so you won't be able to run a s/c in the future.
#23
RE: which car
Definitely get the teggy. The insurance would be a lot for a high schooler, and gas would be a little more too on the mustang. Plus, a teggy putting down 270's at the wheels is WAY faster than a new edge stang. The hp might not be much of a difference, but the weight is. It's probably a mid to low 13 second car, since they are lighter.
#24
RE: which car
ORIGINAL: FordStang5.0
ORIGINAL: hdawg06
I think hdawg06 was reading that the GT has been PI swapped. It hasn't. It was a PI motor swap. Your compression ratio doesn't suck. When people put PI heads on an NPI engine, you get a high compression ratio, which is unfriendly to forced induction. That comment doesn't apply to you.
Let's clear this up, the 97 GT that FordStang5.0 is looking at has a complete 02 engine. It has NOT been PI swapped.
#25
RE: which car
ORIGINAL: hdawg06
#26
RE: which car
its whatever you truly want...if your willing to sacrafice money for a tight lookin/soundin car like i did then there ya go...if not the integra here you come. Im 17 and i pay $180 a month insurance with about every discaunt available as well. Good luck
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
