2pc or 3pc grille delete
RE: 2pc or 3pc grille delete
Honestly, you people that have the 3 piece... didnt it occur to you guys that you could have took 10 min with some cutting device; large pliars etc and just reuse your old shroud? I have the 3 piece too and was pissed cause everyone said to get the 3 piece.... I was like **** I wasted 30$ when i could have reused my old one with 10minutes of work.
Get the 2 piece and reuse your old shroud... if you have any ability at all you can make it look the exact same.
ORIGINAL: WhiteFaleen2001
I have the 2 piece with the stock plastic piece behind it. It works but the horse slides a little because it isn't cut for it.
Easy fix... I forget what i thought of exactly, but definatly an easy fix.
ORIGINAL: handyandy
so the 3rd piece covers up the radiator or what? Does a lot of **** get on it?
You pretty much have one on your car now. Its the big plastic thing behind the actual grille. You can take a look if you wnat.
