Ticking noise...
Ticking noise...
Hey I'm looking for some knowledge. The noise is small, and it only happens when the gas pedal is pressed in a certain amount. All the noise is a small ticking. Like a piece of thin metal being tapped on another piece. It is a rapid sound spinning with the same rpm as the driveshaft, but seems to be coming from the front of the car. Also, it does not happen when the car is revved at a stop. Thanks for all the help.
JB
JB
RE: Ticking noise...
open the hood and rev the car from the throttle boddy and listen close to the heads and if its a ticking comming from the heads it could be a lifter that went bad or its not charging, that happened to me
ORIGINAL: badboystangGT
Oh do you mean lash adjusters?
