Code p1507
Old Jul 21, 2004 | 09:50 PM
callmecobra's Avatar
callmecobra
Default Code p1507
"Idle Air Control Under Speed Error." my friends 98 gt is throwing this code, and it idles funny. anybody know whats wrong?
Old Jul 22, 2004 | 12:49 AM
callmecobra
Default RE: Code p1507
someone, anyone
Old Jul 22, 2004 | 12:54 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
A vacuum leak, a damaged IAC assembly, a stuck IAC valve or throttle valve typically sets this code. The IAC can be checked with a scan tool, sensor tester or multimeter. A vacuum leak is one of the most common causes of this, of course Im sure you know how to check for that. Getting the valve stuck gets caused by carbon build-up usually.
I would spray around with brake cleaner or something flammable if you prefer (hey some people love starting fluid lol) and listen for changes in the idle - which indicate a vacuum leak where you sprayed. If you find none then I would clean the IAC with carb cleaner, then brake cleaner to remove any excess residue from the carb cleaner. When using the carb cleaner flood the whole thing and let it sit for a couple minutes before you spray it out. If that still don't fix it then check or replace the IAC. You should have it fixed by the time you get done with this little list.
Old Jul 22, 2004 | 12:58 AM
callmecobra
ORIGINAL: mdvaldosta
thanks for responding joe. what does iac stand for? as far as vacuum, ill check around for some loose hoses and what not. lol im good at fixing things, im just not the greatest at diagnosis
Old Jul 22, 2004 | 01:02 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
I put more details in my first post, the IAC stands for idle air control valve (or motor as some people call it). It uses a moving pindle to help control the idle. Often times it gets caked in carbon buildup and has trouble functioning and causes idle problems, but it doesn't usually throw a code unless its damaged or there's a vacuum leak.
Its all good nomo, no one can be an expert at everything lol, I call myself a jack of all trades but master of none hehe. I took a 5 hour OBDII seminar about 5 years ago, so I kinda cheated.
Old Jul 22, 2004 | 01:08 AM
callmecobra
lol. i took a year of auto service, but they never got into diagnostics. oh well. i really appreciate the help man, ill check everything out tommarow.
Old Jul 22, 2004 | 01:11 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
I got to take that class, + a bunch of other stuff for free back in my auto parts days
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
mustangheaven
Sep 29, 2015 11:00 AM
