Timing Adjuster
Timing Adjuster
I was just wondering if the Timing Adjuster was worth the money? I was thinkin about buyin one just don't know if it's worth it. I have minor mods like CAI, Upper intake, TB, Steeda ud pulleys, exhaust, and diablo sport tuner. Will it change the timing more than the diablo sport will?
RE: Timing Adjuster
I love my timing adjuster. I felt the difference and saw the difference on my mileage increase. Too easy to install not to do it. I have mine a 4* advance and use 89 octane. I know someone who runs 6* advance on 93. Not sure if he gets anything more than I do with my 4*. but probably.
Oh, rantheman, diablo tuners adjust timing on a percentage. The manual adjuster is better. SCT is much better at the diablo for timing and everything else.
If you plan on getting a tuner or S/C in the near future, then don't get the timing adjuster.
RE: Timing Adjuster
what 04 said, but it wouldn't be worth it to you since you have a diablo sport already.
also, you don't see much at all beyond 4 degrees advanced. at least i didn't. i can only get 91 in california, but i felt strong gains up to 3degrees advanced, a little more - but not much at 4degrees and nothing beyond. i have a manual adjuster - at least they look cool.
RE: Timing Adjuster
If you get the adjuster at a good price and do the work yourself ( I think you will need a puller ) it makes sense. If you have to pay somebody to install it then the XCT hand held tuner makes more sense.
I have seen the timing adjusters used on ebay for less than $100 and new for about $150
The hand held tuner is around $375 ( I think) and you can tweak mixture and a couple of other things - more if you have an automatic.
RE: Timing Adjuster
you won't need a puller, its really easy actually. i got a "demo room" set for $75 on ebay, they were "Mod Max" but are made by Steeda. I intalled them over the Steeda UDP's I have.
09-01-2015 08:16 PM
