water in floorboards
Ok, I just bought a 97 gt and when I lift up the floor mats, there is water in on the floor. No where else, just the driver and passenger floor boards. It is satuarated, but it is enough to tell that it is wet. It is also making the car smell kind of musty. I had this problem with a previous car and I was told it was the a/c system being backed up. I don't know if this is the case right now, the a/c works great. Any ideas? I am big on a car smelling good and this is going to drive me nuts.
RE: water in floorboards
ORIGINAL: trickdriller
if it was the AC , it would probably only leak(not positive on that but pretty sure) on passenger side where drain is . AC /heater stuff is on passenger side . check under carpet & make sure there are no hole anywhere .
you'll have to take out kick panels & plastic trim beside the seats (not sure what that piece is called ) . pull carpet back starting up by front pedals . you wont be able to pull all the way back but it should be enough to see .
[quote]ORIGINAL: blstoff
just pull strait up on trim beside seats , it clips in .
