Sequential taillights blowing fuses
I just installed sequential taillights to my 2001 Mustang GT and twice it has blown my parking lights fuse (no dash lights, parking lights, tail lights, fog lights). Does anyone have any ideas as to why this is happening and what I might be able to do to correct the problem? I'd hate to scrap my new lights!! This is the first modification I've made that affects anything electrical, and I followed the instructions, as much as there was! There was a "flasher module" included, but not any instructions as to installation or placement.
Any help is greatly appreciated!!
RE: Sequential taillights blowing fuses
whatever you do, do not use a larger capacity fuse
because you could damage something else that's
very expensive.
you may have a bad connection which is arcing and
when connectors arc, they draw lots of current.
you may have wired the module in wrong, double check
the wiring diagram.
good luck and the sequentials are very cool imo.
very expensive.
the wiring diagram.
The modified flasher that was sent to me, I don't see where it is supposed to be placed? This may sound basic, but even my husband is having a hard time with this one, so I don't feel so bad! I looked at the directions on the webelectricproducts.com site you linked for me, and it mentions being sent one, but doesn't mention or show a picture of where it goes. Am I missing something that basic?
Once again, thanks for your help!!
C) Trim the WHITE module wire to length and strip about 1/2" of insulation. Using a wire nut, connect it to the new pigtail of the middle socket (this is the old inside socket that you moved to the middle position).
D) Cut the signal wire (orange with blue stripe) of the outside socket about 3-4" from the socket. Strip 1/2" of insulation from the signal wire coming from the outside socket. Trim the BLUE module wire to length and strip about 1/2" of insulation. Using a wire nut, connect it to the signal wire that goes to the socket.
E) Cap off the short harness wire with a wire nut and use some tie wraps to bundle the wires to the harness. This will reduce the chance of pinching a wire against the body of the car.
ORIGINAL: Stangin Stacey
I can't offer much more help than that because my kit required some cutting of wires but it turned out GREAT and I haven't had a single problem with it. Different kit than the one you have I'm sure, mine came with very comprehensive instructions and had some FAQ's already on it.
I want to thank you all for your input. I spoke with the manufacturer today and after running some tests, we determined that one of my harnesses was faulty. He is sending a replacement tomorrow. I'm so glad it was the harness and I can still have my lights. They look so sweet!!
Now if I can just find out where to get some of these nifty "fear this" stickers with the pink flames...they would really set off my car. Naw! Wouldn't go with the red paint!! [8D]
Ok, no stickers....I'd have to move to Maryland!!!
