Running with EGR unhooked
SO if I plug both the inlet of my EGR and the Outlet on my exhaust. Will my car run f****ed up? and, could it be simply tuned out on a factory chip if, I took it to dynojet or something?
RE: Running with EGR unhooked
If you have a diablo tuner or the like you can turn it off. But dont unplug it unless you turn it off. Itll F up your car otherwise. You know how touchy the computer systems are on these things
ORIGINAL: ajmodelski
Well, I dont' have a tuner for it, so would it be bad if I unhook it and drive it like 10 miles? Will it fowl my plugs?
ATM it is open on both sides. I am going to plug the exhaust side and then turn off the egr valve. DO i have to plug it AND turn it off, or just turn it off?
I have another question. Will a Diablo tuner for a 98 work on my 1997? Or do I have to try and have dynojet do it?
Its a mo FO to get back in. Its all rusted and I can barely get to it with my LT's. I figure it will be easier to just unhook it all. Anyways, does a 98 predator tuner work for a 97 gt?
