Last edit by: IB Advertising
Browse all: Repair and Maintenance
- Ford Mustang Gt 1996 to 2004: Winter Tire Reviews
Review and comparison of top products
Snow Tires
RE: Snow Tires
for the amount of money it would cost for 4 snow tires, 4 rims, alignment and all that crap...and to still run the risk of crashing my stang.....
i bought a 92 civic dx....i'd rather total a car that i bought for $750 than put a scratch on the mustang i got for several thousands more......
I've only driven it a few times...basically from where i bought it to my house...and once to my mechanic....and i'm only driving it when theres snow/ice on the roads....the ONLY plus I see is i prob get 30+ miles to the gallon haha... other than that, i'm embarressed to own it...
RE: Snow Tires
ORIGINAL: GT03 TJS
RE: Snow Tires
I just bought from Tire Rack Blizzak Revo 1's mounted and balanced on black steel wheels with lug nuts. Going for traction, not looks. Wheel covers should do fine with the steel wheels. Package was $667 shipped plus there is a $50 rebate to get back. I contemplated the Blizzak WS-50's.
On the tire size, I think you're wasting your money to go with the stock tire size in a winter tire of 245\45R17, unless you have no choice but to use your existing 17 inch wheels. The best traction in the snow should be a smaller contact patch. Recommended size in a 16 inch is 225\55R16, but I'm going with the alternate size of 215\60R16. Tire diameter on the 245\45R17 & 225\55R16 are the same at 25.7 inches. The 215\60R16 diameter is only .5 inch taller at 26.2 inches.
Certainly a few choices in tire make and at least 2 or 3 options on tire size. Good luck with whatever you choose. Oh, and for those impending snow storms, a couple of 40 pound bags\containers of sand in the trunk should help too.
RE: Snow Tires
Stick with your stock size; I wouldn't put any weight in the trunk. If you drive carefully you really won't need it. I've got Daytona ZR's on my GT...P275/40ZR17's on the rear and 245/45ZR17's on the front and it did well in rain and snow. They might be pretty expensive though. I am just starting to shop for new tires and am going to check out more Daytona's. I did a search for tire ratings and came up with some pretty good reviews...good luck.
Whatever you do turn off the traction control; it's truly a P.O.S.! I was up at Lake Tahoe and got caught in about 3" of fresh snow. I pulled onto the highway going up-hill and with the traction control on I was half sideways and couldn't get any speed. Cars were whizzing by me at about forty miles an hour. I reached down, turned off the traction control, straightened right out and got up to a decent speed.
RE: Snow Tires
Yep, stay with stock tire size if using the existing wheels. You don't want to change the ride height (tire diameter) much at all from stock. Extra weight in the trunk is optional. Start off as is, but may be worth having something handy if you think the back end is spinning more than gripping. Whatever is best for you. Good luck.
RE: Snow Tires
No experience yet with my GT in the snow but will find out quick I suppose. In the summer on the track I've gone with turning traction control off. As was suggested it should be fairly quick to figure out. Turning TC off may be the way to go especially trying to get moving in snow, but TC on may have some benefit if you are moving along ok. I'm hoping I don't use up the clutch in the process if it's a snowy winter.
