Which tire size?
Which tire size?
I've been debating on what I should go with in the rears. I'll be deciding on either a 275, 285, 295, or 315. This would be on a 17 in. DD rim. Its uses would be more than just for straight line racing, although I would like to make a few passes down the strip every now and then, but I would like to autocross, and normal weekend cruising. My question is, what is the best tire to go on what I want to do?
RE: Which tire size?
I should've put this in as well... this is for a 17x10.5 rim in the rear of an 04 cobra. So really, I should just take out the 275 option cuz that would be too skinny. The only hold I have on the 315's is that I would either have to use a spacer or shave the IRS bolt. But other than that, I agree... it looks awesome.
ORIGINAL: so1o2k3
Umm I wouldn't even consider the 275 or the 285 for that matter. Unless you want your tires to end up like mine...
[IMG]local://upfiles/31084/A19EF9C90E174F10A0DC7AC1EBABBB55.jpg[/IMG]
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
M3hunter
09-05-2015 03:42 PM
09-01-2015 08:16 PM
