Mark VIII 4.6
Is a Lincoln Mark VIII engine the same as a cobra 4.6 engine?
Would it bolt up directly to the mustang?
Could I use the same Mark VIII wire harness on the mustang?
Would the Mark VIII engine be compatable with a five speed from a 2000 GT Mustang?
yea im actually putting one of these in my stang... like he said some block and heads as the below 99 cobras with different cams(slightly), intake manifold, etc. But if you get one im pretty sure you would bore it and change the internal and cams anyways at least thats my plan
ORIGINAL: droptoppony
Its not entirely the same...same aluminum block and heads but different crank and intake....it can be installed in a mustang.
These are 4v heads correct? Will the 2v pi heads fit on this block?
ORIGINAL: Armydad
May 9, 2024 05:51 AM
