Help on choosing longtubes...
I realize there are many threads on this topic, but this IS a discussion board. So, I would appreciate it if I did'nt get any replies on how I should just search threads. I would like to purchase longtubes in the future and I am not quite sure what brand to go with. I have looked into BBK and MAC. These seem to be the most affordable. I dont want to spend more than about $520 on the headers, so SLP is out. Also, I currently have a MAC O/R Prochamber. Does MAC make arms that could connect from the prochamber to the Longtubes without having to purchase a whole new midpipe?
Thank you for your input.
Ceramics aint going to make a differance on your car. Untill you start puting out outrageous power, it isn't going to matter. As for BBK vs. Mac. I did ALOT of research on this. According to my friend that works in a mustang shop in cali. Most people down there run BBK. Now, on BBK they dent one fo the tubes for clearance of the steering shaft. That is normal, however the Mac's don't have that. I just finished an install of my own long tube Mac headers. They are good, but don't run them open, it works, but it burns alot of gas, doesn't run right unless your flooring it, and has a tendancy to die. These are all because of the lack of mid pipes, which causes there to be little to no backpressure as well as some crappy O2 readings at low RPMs. But, returning to the original topic. Its just a matter of preferance. Buy what works for you price wise. A shop installation will cost you 400-600$ possibly more or less depending on experiance and that stuff. As for a self install, plan for atleast 2-3 full days assuming you know exactly what your going for. Otherwise, it could take alot longer.
Bottom line, pick what YOU want. Mac vs. BBK is a hot subject, but no one seems to have any diffinative evidence to prove one is better than the other. So, pick what costs right. Chrome is good, they will discolor, but they don't corrode, neither do ceramics, but unless your pushing 600hp or so, ceramic isn't going to be any better.
Hope that helps you.
ORIGINAL: ajmodelski
ORIGINAL: Fryguy22
First off ceramic vs chrome has nothing to do with power. Its a different finish. Chrome WILL rust and ceramic won't. Don't waste your money on chrome. As for BBK vs MAC I have heard mixed reviews. I am not sure what you are talking about with your midpipe. Why would you extend it with longtubes? wouldn't you want to shorten it? anyways if your midpipe is compatible with LT's then definately god with MAC. LT's are made to match up with same brand mid-pipes, or at least it is a lot easier.
I am wondering if I can buy shorter arms that would connect to the headers without having to buy a whole new midpipe.
