throttle body and plenum?
Old Oct 20, 2006 | 04:11 PM
meyerj88's Avatar
meyerj88
Default throttle body and plenum?
ok let me get this straight. a throttle body is what regulates the amount of air going into the engine right? when you press the gas pedal you are letting more air in thereby causing the computer to put more fuel in. also what is a plenum?
Old Oct 20, 2006 | 04:36 PM
Sap's Avatar
Sap
Default RE: throttle body and plenum?
The throttlebody is basically a round cylinder that has a blade in it which opens or closes to allow more air into it.
The plenum is where the air from the TB goes into before going into the intake manifold.
E.
Old Oct 20, 2006 | 05:03 PM
4ZZS's Avatar
4ZZS
You guys are both right.
The plenum is basically a 90 degree elbow that connects the throttle body to the intake manifold. The air passes the throttle body horizontally, the plenum turns it 90 degrees to blow vertically (down) into the intake manifold. The computer does the math to mix the correct amount of fuel with the air you are supplying. You could almost replace the plenum with a nice large piece of PVC pipe, but there's a little bit to be said about the cosmetics of such a modification.
You gain a little bit of extra horsepower by installing larger and smoother TB&Ps because you can get more air into the engine through a larger and smoother path than the stock parts. The new TB might operate a little smoother and therefore give you quicker throttle response.
These changes will not make a huge difference but for a few bucks you get a few extra horses and maybe a nicer look. Make SURE you have switched from the paper air filter to a K&N type so you can get the air to the TB&P.
Old Oct 20, 2006 | 06:46 PM
meyerj88's Avatar
meyerj88
thx for the info
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
guitarman376
Sep 30, 2015 05:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
2poor4u2
Sep 26, 2015 11:08 AM
