Cams too big?
Old Oct 23, 2006 | 11:04 PM
phalcrow's Avatar
phalcrow
Default Cams too big?
I have a 1996 GT with a 1997 block and PI heads. I have been running the Comp Xtreme energy cams XE-262AH (comp part #102500) for quite some time with no problems. I just swapped them for the XE-270AH (comp part #102600) cams and as soon as I started it up, my motor sounded like a diesel. I couldn't pinpoint it the noise, it wass all over the engine. After driving a few blocks, I decided to put the old cams back in (8 hours later) and had a new noise, sort of like an exhaust leak. I reved the engine to 3-4 grand and POP! TACK, TACK, TACK, TACK every revolution. Sounded like a midget with a sledge hammer in my block. I think I had a valve clearance problem. Any suggestions?
Old Oct 23, 2006 | 11:43 PM
droptoppony's Avatar
droptoppony
Default RE: Cams too big?
You have PTV...Piston To Valve contact...when installing cams on a 2V you must degree them in or else you can have PTV. You got lucky with the 262ah's but they are more mild, when going to 270ah's degreeing is a must. You probably now have bent valves and lots of issues.
Old Oct 23, 2006 | 11:50 PM
phalcrow's Avatar
phalcrow
Thanks. Any good links on how to degree cams? What could be some of these other "issues" as well as bent valves. I've already accepted the fact that I need new valves. Would different pistons help?
Old Oct 23, 2006 | 11:51 PM
kendiesel's Avatar
kendiesel
ORIGINAL: droptoppony
+1 Your gonna need new valves.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
