I NEED HELP (QA1 TUBULAR FRONT SESPENSION)
Okay i bought the QA1 Tubular k member, and tubular a arms with coil over springs and they sent it without hardly any instructions at all. I have taken off my stock k member, removed the nuts from the stock a arms and the struts. Now i have started to assemble the new k member with a arms and coil over springs. my question is if anyone has this setup and can help me with completely mine? The a arms came with two washers per a arm and i am confused on what those are for.....i think maybe that they are spacing washers because there is a little play right now. also the a arms came with a grease fitting for the bottom of the a arm and im unsure of what to use for that, axle grease, white litheum grease...etc.? And also the fact that i have no idea how to install coilover springs on to the struts. do i have to take off the strut?? Does anyone have a link with better instructions or maybe some detailed pics?
THX so much
THX so much
RE: I NEED HELP (QA1 TUBULAR FRONT SESPENSION)
These are the only pics I could find from when I installed my QA1 set up.
[IMG]local://upfiles/37288/1A04403ADB0B43558F54EE6F3643F9A6.jpg[/IMG]
[IMG]local://upfiles/37288/8970A78FC31F45A18ACD675BC7B00D51.jpg[/IMG]
ORIGINAL: JimboGT01
THX so much
THX so much
ORIGINAL: JimboGT01
I have the stock struts, Did your k member come already assembled to the A arms?
If you got the QA1 coilover kit and springs then you need their threaded struts.
Aska specific question and maybe I can help.
Are you sure that i need different struts?
