Gears grinding!@#
Old Nov 1, 2006 | 12:30 AM
astrodoggie3000's Avatar
astrodoggie3000
Default Gears grinding!@#
I have an 02 GT with a 5-speed. Whenever i first start driving it, the gears grind real bad from 1st to 2nd... and a little when i shift to 3rd. Are my synchros going bad, or do i need to change my shifter? I have a stock shifter.
Old Nov 1, 2006 | 12:33 AM
djb1187's Avatar
djb1187
Default RE: Gears grinding!@#
times for new synchros bro, mustangs have the worse trannys I swear...im in the process of replacing mine due to worn synchros
Old Nov 1, 2006 | 05:00 AM
FDNYBullitt's Avatar
FDNYBullitt
There is a TSB on these trannys for that problem, bad synchros, sliders and gears from the Factory. If by some chance your still under warranty, Ford will rebuild it for free, if not then sadly your on your own, good luck.
Old Nov 1, 2006 | 11:44 AM
DTK's Avatar
DTK
+1 FDNY
I had mine at the dealer for a noise (not grinding) going into second.
They checked the car out and said it was nothing but normal on the 3650.
There is a TSB #042613 for 1-2 gear clash / grind on the 3650.
My car has a 5 yr powertrain warranty.
Check if yours does.
Old Nov 1, 2006 | 10:19 PM
astrodoggie3000
Has anyone repaired this problem? If so... did it correct the poblem? How much didi it cost? Any help on this would be appreciated.
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
