does anyone know if the gauges froma 03 mach 1 will fint in a 01 GT ??? off the top of my head i think they should but i was just wondering if anyone knows for sure
I dont like the gauges myself. Just my opinion. But im almost positive they will fit. Thats all a Mach1 is is a GT with a bigger and better engine and a different rearend and a few interior changes.
"Thats all a Mach1 is is a GT with a bigger and better engine and a different rearend and a few interior changes."
Your are partially correct. The engine is not bigger but it is higher output. The suspension and braking systems are also superior on the mach as well. Dont forget the exterior.
You can't use the gauge cluster from a Mach1, or any other newer Mustang for that matter, without getting the ECU reprogrammed at the dealer for the new gauge cluster. While it will physically be identical, the theft deterrent system will prevent the car from starting until you get it calibrated.
